thickness of sides http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=8573 |
Author: | Steve H [ Sat Sep 23, 2006 4:24 am ] |
Post subject: | |
I'm getting ready to start building guitar #3. In the past I have thicknessed the sides to 2.4mm or .090 before bending.Do you have any advice or does this sound good? |
Author: | John How [ Sat Sep 23, 2006 4:34 am ] |
Post subject: | |
You can safely go to .080-.085" on a large guitar, with my smaller guitars I often go to .070" of course depending also on the wood you are using. |
Author: | Mike Collins [ Sat Sep 23, 2006 9:38 am ] |
Post subject: | |
The side thickness depends on the wood used and the desired sound of the guitar being made! If your using figured wood you may have to thin to .080 but for well quartered wood .095 is easy to bend! Remember thin sides make for a weak sound if the body is deep in thickness-and the top is loose.(it makes a great quick response but decays fast)-Maybe good for flat picking! It really is best to leave your sides as thick as you can- work with and do the rest of your body tuning with the thickness of the top and the bracing along with -back thickness . Mike collins www.collinsguitars.com |
Author: | Martin Turner [ Sat Sep 23, 2006 9:39 am ] |
Post subject: | |
I generally work my IRW sides to about 0.095" on my steel strings....a little thinner on my classicals. Each piece of wood is different so I judge final thickness by testing "floppiness" as I work down to final thickness with the cabinet scraper. |
